How to access/use the E16/64 from the R prompt - Part 1
Moderator: censix
Postby censix » Wed Jun 12, 2013 8:13 pm
censix
Re: How to access/use the E16/64 from the R prompt - Part 1
Postby censix » Thu Jun 12, 2014 6:45 pm
Important:
Please note that the Epiphany always shows up as the second device in the list! The first evice d[[1]] is always the ARM host.
The Epiphany is d[[2]].
censix
Postby Tohru » Fri Jan 02, 2015 1:52 pm
Thank you for your nice introduction of ROpenCL. I have tried to install it, but 'parallella-ROpenCL_0.1-1.patch' is not fit for ROpenCL 0.1-2. I hope the patch will be revised.
Tohru
Postby NelsCarlson » Fri Aug 07, 2015 2:22 pm
NelsCarlson
Postby piotr5 » Sat Aug 08, 2015 12:05 pm
not sure how much you know about patch.
basically you first type "cd pathname" where pathname is the location of whatever sourcecode. then do "patch -p1 <patchname" where patchname is the name of whatever patch-file you use, probably "../parallella-ROpenCL_0.1-1.patch" in your case. never tried "man patch"?
Postby NelsCarlson » Mon Aug 10, 2015 2:11 pm
NelsCarlson
Postby piotr5 » Tue Aug 11, 2015 1:15 pm
why not use ? as mentioned above, you'd need to alter the files manually to reflect the changes intended by the patch...
Postby davewr2015 » Sun Aug 30, 2015 1:05 am
Has anyone tested this with R3.03?
The latest README implies that it will work -- however -- as noted the patch files are out of date.
Any thoughts? Is there a new (working) procedure?
davewr2015
Return to R
