n00b steps for your first Parallella
Postby Olaf » Sun May 15, 2016 9:39 pm
Olaf
Re: n00b steps for your first Parallella
Postby leon_heller » Thu May 19, 2016 11:04 am
Debug build.sh run.sh src
doesn't work on my Kickstarter board:
-bash: Debug: command not found
However, the following works OK:
parallella@parallella:~/epiphany-examples/apps/hello-world$ ./build.sh
parallella@parallella:~/epiphany-examples/apps/hello-world$ ./run.sh
0: Message from eCore 0x8ca ( 3, 2): "Hello World from core 0x8ca!"
1: Message from eCore 0x84b ( 1, 3): "Hello World from core 0x84b!"
2: Message from eCore 0x84b ( 1, 3): "Hello World from core 0x84b!"
3: Message from eCore 0x888 ( 2, 0): "Hello World from core 0x888!"
4: Message from eCore 0x849 ( 1, 1): "Hello World from core 0x849!"
5: Message from eCore 0x88b ( 2, 3): "Hello World from core 0x88b!"
6: Message from eCore 0x88b ( 2, 3): "Hello World from core 0x88b!"
7: Message from eCore 0x8ca ( 3, 2): "Hello World from core 0x8ca!"
8: Message from eCore 0x80a ( 0, 2): "Hello World from core 0x80a!"
9: Message from eCore 0x808 ( 0, 0): "Hello World from core 0x808!"
10: Message from eCore 0x8c8 ( 3, 0): "Hello World from core 0x8c8!"
11: Message from eCore 0x8c9 ( 3, 1): "Hello World from core 0x8c9!"
12: Message from eCore 0x88a ( 2, 2): "Hello World from core 0x88a!"
13: Message from eCore 0x88b ( 2, 3): "Hello World from core 0x88b!"
14: Message from eCore 0x8cb ( 3, 3): "Hello World from core 0x8cb!"
15: Message from eCore 0x84a ( 1, 2): "Hello World from core 0x84a!"
16: Message from eCore 0x88a ( 2, 2): "Hello World from core 0x88a!"
17: Message from eCore 0x84b ( 1, 3): "Hello World from core 0x84b!"
18: Message from eCore 0x848 ( 1, 0): "Hello World from core 0x848!"
19: Message from eCore 0x8ca ( 3, 2): "Hello World from core 0x8ca!"
Leon Heller
G1HSM
leon_heller
Postby DonQuichotte » Thu May 19, 2016 12:01 pm
Hi leon
Olaf's tutorial is fine.
ls
•./run.sh
The "ls" command is like the "dir" command under DOS / Windows: it lists local directories and files.
Debug is the directory under the current directory
build.sh and run.sh are the shell scripts
src is another folder
Maybe it will be fine for you if you replace ls with "ls -la" or simply "ll".
Under Linux you append "--help" or use "man..." to get help.
Example: "ls --help"
It's quite verbose you'll see ;)
DonQuichotte
Postby leon_heller » Thu May 19, 2016 12:20 pm
Thanks, Don.
It still can't find the Debug command. The Debug directory is there. Does
mean that I'm supposed to enter the Debug directory (cd Debug) before running the shell scripts.
I'm not too concerned as I got it to work, anyway.
Leon Heller
G1HSM
leon_heller
Postby sebraa » Thu May 19, 2016 1:14 pm
The line "Debug build.sh run.sh src" is the output of the "ls" command.
It is not a command you are supposed to type. :-)
Postby leon_heller » Thu May 19, 2016 1:32 pm
Thanks sebraa,
I was beginning to think that it was something like that.
Leon Heller
G1HSM
leon_heller
Postby Olaf » Thu May 19, 2016 8:57 pm
I added the "./build.sh"
Apparently the first time you have that example, it is not compiled yet and certain folders do no yet exist.
When I created the example I already did build the example so it ran.
Olaf
