[SOLVED] Parallella memory random behaviour
Postby SoMia » Sun Jun 26, 2016 1:09 pm
Hi All,
when i try to run my code which i use the external memory of parallella to read input file and to store output file , memory has random behaviour which mean that first run it results no output , second run the output appears , or first run output apear then second run output deosn`t apear and so on ... every run has different output .
can you help me ?
SoMia
Re: Parallella memory random behaviour
Postby sebraa » Sun Jun 26, 2016 8:41 pm
Accesses to off-core memory (this is especially true for external memory, less for on-chip memory) do not follow strongly-ordered memory semantics. This means that writing to a variable and reading it often returns the previous value, not the one you just wrote! This behaviour is very timing-dependent.
Otherwise, check line 42 in your code.
Postby SoMia » Thu Jun 30, 2016 11:49 am
SoMia
Postby polas » Thu Jun 30, 2016 3:06 pm
Can you post the code anywhere so we can look at it & advise. I suspect there are relatively simple approaches that can be adopted to solve this.
polas
Postby sebraa » Fri Jul 01, 2016 10:20 am
