Example: Reducing run time by moving code to internal memory
Moderator: Dr.BeauWebber
Postby Dr.BeauWebber » Tue Jun 18, 2013 6:46 pm
Dr.BeauWebber
Re: Example: Reducing run time by moving code to internal me
Postby timpart » Wed Jun 19, 2013 6:52 am
You mentioned wanting to track down where a routine comes from. The linker e-ld has an option to print out which input file a symbol is in. Use -y or --symbol-trace followed by the symbol name (you may need a leading underscore on the name). Doesn't seem to pick up references from libraries though.
Alternatively the -M map option on the linker might give you a clue as ou could see what is close to that routine and there might be another name you recognise.
Postby ysapir » Wed Jun 19, 2013 1:14 pm
"e-objdump -D" will list a disassembly of the binary image. Doing "e-objdump -D file.e | grep '>:'" is what I use to see objects placement.
Can you please explain what "matrix with shape : 10x9x8x7" means? Is it a 4-dimensional array?
In your exercise, do you yry to invert the matrix (i.e., find its reciprocal) or to transpose it?
Postby Dr.BeauWebber » Wed Jun 19, 2013 2:31 pm
Thanks Tim,
Nice to know these things.
Done more searching and it turns out that aeabi_idivmod is relevant to the linux version of the gcc compilations, but not the e-gcc compilations.
it would be nice to profile the code generated by e-gcc, but when I compile with -pg I get :
/opt/adapteva/esdk/tools/e-gnu.arm7l/bin/../lib/gcc/epiphany-elf/4.7.0/../../../../epiphany-elf/bin/ld: cannot find -lc_p
I have tried manually searching for a library libc_p.a or whatever and not found it.
Dr.BeauWebber
Postby Dr.BeauWebber » Wed Jun 19, 2013 2:42 pm
Dr.BeauWebber
Postby ysapir » Wed Jun 19, 2013 3:05 pm
Interesting. Everybody knows how to transpose a 2-D matrix. I can easily imagine how to transpose a 3-D array (rotate the cuboid around the principal diagonal - but even then, I think there are 2 options for the amount of rotation - 120 degrees and 240 degrees). I have hard time imagining how to transpose a 4-D one...
Postby ysapir » Wed Jun 19, 2013 3:10 pm
Postby Dr.BeauWebber » Wed Jun 19, 2013 9:17 pm
Dr.BeauWebber
Postby Dr.BeauWebber » Wed Jun 19, 2013 9:22 pm
Dr.BeauWebber
Postby ysapir » Thu Jun 20, 2013 12:19 am
Return to APL
