ESDK installation problem
Postby Marcio » Tue Jun 25, 2013 3:03 pm
Marcio
Re: ESDK installation problem
Postby simoncook » Tue Jun 25, 2013 3:52 pm
Hi Marcio,
To check the binary works, if you go into the directory where e-gcc is and run ./epiphany-elf-gcc, does the program run correctly?
Also I assume you have checked your PATH, does everything look right there?
Useful SDK Links: - - -
simoncook
Postby ysapir » Tue Jun 25, 2013 4:32 pm
Postby Marcio » Wed Jun 26, 2013 8:04 am
Marcio
Postby Marcio » Wed Jun 26, 2013 8:15 am
Regarding to the ZYNQ 7020 board, we have the Epiphany 16 core chip as well. Are going to be able to work with it using the ZYNQ board, or we should have a hardware description file for it? Because I saw that there is only for the Zedboard. Perhaps, it is a newbie question but I have no clue about this topic...
Greets,
Marcio
Postby simoncook » Wed Jun 26, 2013 10:07 am
If you type arm and then tab twice, do you see for a compiler either a) arm-linux-gnueabihf-gcc or b) arm-linux-gnueabi-gcc?? The tools you downloaded were built with the latter but I suspect you see the former. Attempting to run a binary with a different ABI will produce the unhelpful message "No such file or directory".
As I do not believe there is a version of the tools precompiled for this ABI, you will have to build the tools yourself. If you refer to https://github.com/parallella/epiphany- ... /README.md and https://github.com/adapteva/epiphany-sdk for details on how to do this. If you have any issues please let us know and we will help.
simoncook
Postby Marcio » Wed Jun 26, 2013 11:12 am
Marcio
Postby ysapir » Wed Jun 26, 2013 1:49 pm
Postby ysapir » Wed Jun 26, 2013 1:56 pm
Postby Marcio » Thu Jun 27, 2013 8:08 am
Marcio
