When using EMIO do I need to rebuild the FSBL
Postby wiegmink » Thu Mar 30, 2017 1:31 pm
Hi all,
Not sure if the questions belongs here, but is is closely related to HW design. I've added SPI0 in the MIO configuration, io is routed through EMIO to a component in the PL (and from there to the outside world). Xilinx issue 47511 taken into account. Question is if I use EMIO do I need to rebuild the FSBL? (Or maybe in general do I always need to rebuild the FSBL if the configuration is changed?)
Thanks.
Klaas
wiegmink
Re: When using EMIO do I need to rebuild the FSBL
Postby wiegmink » Fri Mar 31, 2017 12:01 pm
In the mean time I've got output signals, so the answer is you don't need to rebuild the FSBL. (Apparently posting questions already helps.) :)
The only thing is that the speed option in the spidev_test.c doesn't do much. Output clock is pretty fixed at 645 kHz. Anyway, next thing to look at, this item is closed.
Klaas
wiegmink
Postby olajep » Sat Apr 01, 2017 1:48 pm
