md5sum parabuntu img
Postby beco » Thu Apr 13, 2017 4:21 am
Dear parausers,
I am having trouble booting my microserver board with the image.
It never gets an IP address. As I don't have HDMI monitor/cable/connector, nor RS232, I am flying blind.
First thing, then, can anyone confirm if my download is ok?
Is this the MD5SUM of the following image?
$ md5sum parabuntu-2016.11.1-headless-z7010.img
4b8d896a49e71de7a1cd312b5cd2bead parabuntu-2016.11.1-headless-z7010.img
I can't find the info on the net. Note that I calculate it after unziping, because I already had deleted the ziped file.
Thank you. I hope we find soon what is the cause.
Beco.
PS. I saw some troubleshootings, but they ask to boot it with HDMI to change IP to static. I can't do that.
Also, for some reason, I cannot mount the 32GB sd card I copyed with "dd". It gives me the following error:
$ mount /dev/sdb1 /media/usb0
mount: wrong fs type, bad option, bad superblock on /dev/sdb1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
And dmesg (syslog the same) just give this message:
[20597.417471] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive
beco
Re: md5sum parabuntu img
Postby beco » Thu Apr 13, 2017 4:46 am
I've found sha256sum in the github repo:
$ cat sha256sum.txt
98157535a9c851ff238f64d84207036f4ccf9e437d0a3eb7d9d0e0cf91c24a82 parabuntu-2016.11.1-hdmi-z7010.img.gz
dac43991996e1d6319a947d1812d0fbcb4c438e0fb1d8c6a00d25b2427d6123c parabuntu-2016.11.1-hdmi-z7020.img.gz
ac314a4fb9ab04ccef46e76727aadfab8b6045b188c975ba13f8657a6151b6c7 parabuntu-2016.11.1-headless-noelink-z7010.img.gz
2d20f3badce1478741bb08009867a1e4bf801e03152de820b27206fedd937cd5 parabuntu-2016.11.1-headless-noelink-z7020.img.gz
3d88e8c979b09d1bb31dd6628a66be4e6ddc840a6d35131689e6c3f576f9fd08 parabuntu-2016.11.1-headless-z7010.img.gz
2f3b5efbaad7e20cf87227ef3df73f23fd15d05438337d9e4ff30aeb007d910a parabuntu-2016.11.1-headless-z7020.img.gz
beco
Postby sebraa » Tue Apr 18, 2017 4:37 pm
Postby olajep » Tue Apr 18, 2017 5:15 pm
