Compiling Objective-C code for the Epiphany
Postby CocoaGeek » Thu Apr 20, 2017 4:49 am
CocoaGeek
Re: Compiling Objective-C code for the Epiphany
Postby olajep » Thu Apr 20, 2017 10:31 am
Postby CocoaGeek » Thu Apr 20, 2017 3:24 pm
Thanks olajep, I'll give that a try and report back.
CocoaGeek
Postby CocoaGeek » Fri Apr 21, 2017 4:47 am
... that worked for TYPE_PACKED,epiphany_special_round_type_align, TYPE_USER_ALIGN and GET_MODE_ALIGNMENT. epiphany_adjust_field_align however doesn't have a similar #if ...
CocoaGeek
Postby CocoaGeek » Tue Apr 25, 2017 4:05 am
CocoaGeek
Postby GreggChandler » Tue Apr 25, 2017 4:49 am
Try using a different linker script. The Epiphany III supports putting code and data into the external shared memory with the appropriate script. The performance suffers when code or data is put there, but it might still let you use some Cocoa code.
GreggChandler
Postby CocoaGeek » Tue Apr 25, 2017 5:15 am
CocoaGeek
Postby olajep » Tue Apr 25, 2017 9:53 am
Postby CocoaGeek » Tue Apr 25, 2017 2:39 pm
That's great! Thank you very much Ola! :)
CocoaGeek
Postby CocoaGeek » Sat Apr 29, 2017 6:49 am
I can confirm that it is working on the device. Haven't tested everything yet, but basic object life cycle (alloc,init, property access, dealloc) is working :)
Once again, thanks Ola for the support :geek:
CocoaGeek
