VMWare and parallella
Postby parimey » Sat Jun 10, 2017 10:04 am
Can we use virtual machine VMWare on Parallella board? I want to run a software (not software actually it itself is an OS, Contiki OS for IoT). So to run this OS I would require VMWare. Although if there is any way of running this OS on prallella please tell me and also about virtual machine on parallella. Thank you!
parimey
Re: VMWare and parallella
Postby pgater » Sun Jun 11, 2017 10:02 am
Hi Parimay,
I am a fan of Contiki as it is a very well supported system, the stack is a few hundred bytes and non essential operating system symbols can be stored in ROM, which in this case would be the 32k of DRAM for each chip. Unfortunately I have not had the time (due to various reasons) to get a version running on the Parallela board and I also delayed when the command set was changed :( .
For VMware Instant Contiki may be the solution, it runs OK on my Windows 10 PC. All you do is download and install.
It can be found here http://www.contiki-os.org/start.html
I am still learning C amongst other things, but I have had a look around the Contiki system and my conclusion was that the Rime system was not suitable without a large amount of work and the ipstack would be too large .
Could I draw your attention to a recent blog entry here on OpenSHMEM for Epiphany. This may provide a good way to communicate between each cpu with a small operating system, but I have not had time to investigate. It can be found here https://www.parallella.org/blog/
Note that Adam Dunkels, creator of the Contiki system advises you to develop the system off the target board, ie on a PC, which is why I suggest Instant Contiki.
If you really want to compile on the actual Parallella board then I suggest you follow the links to the Github site and download the zip file.
I have also got a number of downloaded papers and U-Tube links to presentations if you are interested, as Contiki documentation is a bit sparse.
Sorry if I am rambling on! :D Hope this helps :D
Paul
pgater
Postby sebraa » Mon Jun 12, 2017 11:51 am
No, you can not run VMware on the Parallella board.
Postby pgater » Tue Jun 13, 2017 10:05 am
Hi Sebraa/Parimay,
Yes, quite correct, VMware does not run on the parallella board. But as I said you can download the contiki zip file from Github, and I should have made clear without VMware, and compile on the parallella board if you really want to. Thought I would just reply to clear up any confusion. :D
Paul
pgater
