Parallella FMCOMMS image
Moderator: tjt7a
Postby kaklik » Sun Aug 13, 2017 8:19 am
I have downloaded the according to the short guide in this presentation
Then I booted the Parallella in hope there will be an FPGA design and compiled gnuradio block to interface ADC through FPGA pins.
(The image has corrupted the Ethernet configuration. Therefore, I need to use the serial console to fix it)
But unfortunately, there is no gnuradio software in that image nor FPGA design files.
Have I missed something, or it is a correct fact?
Where should I obtain the best starting point FPGA design and source code for gnuradio with ADC and FPGA interface?
kaklik
Re: Parallella FMCOMMS image
Postby olajep » Wed Aug 16, 2017 5:32 pm
1. You need to build gnuradio from source. This is described in the slides.
2. These posts describe what hardware is required:
viewtopic.php?f=20&t=3985#p18589
viewtopic.php?f=20&t=4025#p18859
// Ola
