LDR/STR instructions
Postby Gravis » Mon Jul 15, 2013 6:19 pm
do the LDR and/or STR instructions have to use addresses that are aligned to 32-bits or could you load/save the 16-bits in the middle of a 32-bit register? if it does have to be aligned, would it completely overwrite the entire 32-bits or just the 16-bits written to?
Re: LDR/STR instructions
Postby ysapir » Mon Jul 15, 2013 7:45 pm
The LDR/STR instructions can save a byte, a short (half-reg), a word (whole-reg) or a double-word (reg-pair). Depending on the <size> the address alignment can be 8-bit, 16-bit, 32-bit or 64-bit, resp.
The part of the register to load/save is always the least significant <size> bits.
Postby Gravis » Tue Jul 16, 2013 12:15 am
Postby aolofsson » Tue Jul 16, 2013 12:40 am
An illegal misaligned LDR/STR causes a software exception. (ie vector to IVT, address 0x4)
Postby timpart » Tue Jul 16, 2013 6:35 am
A misaligned address also sets EXCAUSE to 010 in the status register (p47), since that interrupt can be used for several reasons (see table 21). Talking of which, what does EXCAUSE get set to for invalid instruction?
