Documentation Errors
Postby tono » Mon Dec 17, 2012 10:00 pm
I thought I start a thread for documentation errors.
First a very minor one:
In Epiphany Architecture Reference (G3), REV 3.12.10.03.
On page 62, The table 21, "Pipeline Stage Description", seems to be missing stage 7 (but have a stage 9).
tono
Re: Documentation Errors
Postby aolofsson » Mon Dec 17, 2012 11:42 pm
Great! Just fixed it. I owe you a beer :D
Postby Watse » Tue Dec 18, 2012 7:23 am
Watse
Postby aolofsson » Tue Dec 18, 2012 12:49 pm
Nice try :D It's going to be hard to make beer a formal reward. Too many disclaimers needed.
Postby jar » Tue Dec 18, 2012 1:42 pm
Postby timpart » Fri Dec 21, 2012 7:57 pm
In Epiphany SDK reference 3.12.10.3
Page 9 "compl" should be "complete." (might be meant as a joke.)
Page 42 "scree" should be "screen" (unless developing on the side of a mountain)
P.S. Personally I wouldn't put IADD etc in the integer instruction table as it could cause confusion as to when they can be used.
Postby timpart » Thu Jan 03, 2013 10:22 pm
Thanks for the instruction set decode in Arch Ref 3.12.12.18
Page 129 Table 37
SUB I presume the value 1 means subtract.
S (bit 4 in LDR/STR) isn't documented. 0=Load, 1=Store?
Page 130 Table 38
The 3rd line of the load/store section is described as "LDR/STR (PM-IMM) (16)". Should this be "LDR/STR (PM) (16)"? Bits 7 to 9 contain Rm0 to Rm2 not I0 to I2, and there is no IMM3 mentioned on page 107
The 4th line of the load/store section is described as "LDR/STR (DISP) (16)". This should end (32).
Postby aolofsson » Mon Jan 07, 2013 2:10 am
Postby mrgs » Sun Jan 13, 2013 6:10 pm
mrgs
Postby ysapir » Mon Jan 14, 2013 4:50 am
@mrgs,
Programming and activating the DMA engine should be done using a descriptor. You should not program the DMA registers directly (except for DMACONFIG).
According to Table 32, next-ptr, stride (inner/outer, src/dst) and count (inner/outer) are all 16-bit values. The source and destination addresses are 32-bit each and can point to anywhere in the memory space.
Thus, in the sample descriptor, the configuration is to transfer bytes as a master w/o chaining DMA's. The strides for the inner loops are both 1 (meaning, a contiguous vector in memory), the inner loop count is 8 for transferring 8 bytes and the outer loop has only one iteration (so we transfer a 1-D contiguous array of bytes). The outer stride is not important here since there is no outer loop. Two values of 0 are just arbitrary. The addresses show copy from internal to external memory.
Once the DMACONFIG register is written with this descriptor's address and with a kick-start signal, the transfer begins.
Note that the descriptor's memory must not be altered while the transfer is in progress, or some undefined behaviour will occur :!:
BTW, the # prefix for immediates is not mandatory and is a matter of style.
