Epiphany uses
Epiphany uses
Postby Marcus D. » Tue Jul 23, 2013 12:16 pm
What kind of applications would Epiphany excel at compared to GPGPU?
Marcus D.
Re: Epiphany uses
Postby Hoernchen » Tue Jul 23, 2013 12:49 pm
It excels at power consumption, and when your tasks are not entirely "embarassingly parallel" because the epiphany CPUs are independent and can branch without having to wait/mask stuff.
Hoernchen
Re: Epiphany uses
Postby Marcus D. » Tue Jul 23, 2013 2:57 pm
Thanks. The power consumption is definitely a major plus!
So is it seen as the same as a CPU but better FLOPS/W performance?
After all, you can now get 16 x64 cores in a box now relatively easily if somewhat more expensive than a parallella board! :lol:
FPGA, I can understand.
Is it meant to sit somewhere between CPU and GPU in terms of ease of use?
Marcus D.
Re: Epiphany uses
Postby Gravis » Tue Jul 23, 2013 3:10 pm
Re: Epiphany uses
Postby aolofsson » Wed Jul 24, 2013 2:03 am
gravis,
Thanks for the favorable comparison of GPUs and Epiphany! Lots of good points. Sadly most folks these days get hung up on just quoting GFLOPS numbers.
Re: Epiphany uses
Postby Gravis » Wed Jul 24, 2013 8:34 am
Re: Epiphany uses
Postby naeger » Thu Jul 25, 2013 9:35 pm
naeger
Re: Epiphany uses
Postby tnt » Thu Jul 25, 2013 11:20 pm
GPU basically can execute a lot of threads in parallell (like thousands !), but they must pretty much all do the same exact task at the exact same time, just working on different data. So that's perfect for example to compute a filter on an image, because the exact same operation will produce each ouput pixel independently, only with different input pixels and you can launch thousands of // threads each processing a single output pixel.
Epiphany OTOH is much more parallell than CPUs because it has 16/64 cores, but much less than a GPU because you only get 16/64 threads. But those are not forcibly linked in anyway, each can execute completely different task.
(it's obviously a little simplified, but that's the general idea)
Re: Epiphany uses
Postby LamsonNguyen » Fri Jul 26, 2013 2:16 am
Another way to think about it is that a GPU is a factory with each worker doing the same, small task requiring little skill. The Epiphany is like a group of 16/64 craftsmen whereby one person could work on a painting, another could build a chair, etc.
LamsonNguyen
what is this "simile" thing you speak of?
Postby Gravis » Fri Jul 26, 2013 6:02 am
