SDK build fails on arch linux
Postby CIB » Wed Jul 31, 2013 9:57 pm
I get this problem upon building binutils:
/home/cib/projects/parallella/srcw/bfd/doc/bfd.texinfo:325: unknown command `colophon'
/home/cib/projects/parallella/srcw/bfd/doc/bfd.texinfo:336: unknown command `cygnus'
Quick google gives me this: http://sourceware.org/bugzilla/show_bug.cgi?id=15183
That bug ought to be fixed in the latest version, but apparently it isn't in the distributed one?
CIB
Re: SDK build fails on arch linux
Postby CIB » Thu Aug 01, 2013 12:54 pm
CIB
Postby CIB » Thu Aug 01, 2013 1:11 pm
I think I get why it's not working. Looking at: https://github.com/parallella/epiphany-sourceware
It seems the stuff in there hasn't been updated from upstream in 2 years. So obviously, tools(such as the newest perl release) stop supporting such an old version. I guess people on "long term distros"(like ubuntu LTS) may be fine, but using arch this is a complete disaster.
CIB
Postby simoncook » Thu Aug 01, 2013 1:41 pm
Hi CIB,
I am aware of this issue (I've hit and found the same solution myself yesterday in fact).
We have more up to date repositories (see viewtopic.php?f=13&t=471) which I believe already have the fix for this issue in (if it doesn't there'll soon be a patch added that does fix it). I am just setting up an arch linux system to build and confirm, thanks for bringing this to our attention.
Useful SDK Links: - - -
simoncook
Postby CIB » Thu Aug 01, 2013 3:02 pm
Thanks for your reply. I tried using the more recent repos you suggested and encountered the same issue as in the initial post.
CIB
Postby CIB » Thu Aug 01, 2013 4:26 pm
Just a heads up: I installed debian 6 on virtualbox and the SDK built just fine in that.
CIB
Postby Gravis » Fri Aug 16, 2013 1:30 pm
Postby Gravis » Sun Aug 18, 2013 10:12 pm
so... what is it?
Postby CIB » Mon Aug 19, 2013 8:17 am
Install debian 6 in a VM. That's the only way I've gotten it to work.
CIB
Postby simoncook » Mon Aug 19, 2013 9:47 am
I have now cherry-picked some changes from the mainline branches and fixed the rest of the build failures manually. If you update the epiphany-binutils-2.23 branch, this should now work.
simoncook
