How do you compile e-lib?
Postby CIB » Thu Aug 01, 2013 5:59 pm
CIB
Re: How do you compile e-lib?
Postby ysapir » Thu Aug 01, 2013 7:20 pm
When you build the toolchain, you will end up with an INSTALL directory (unless you put a different option) where you built the tools. This INSTALL should be renamed to e-gnu.armv7l (or whatever is your target name) and moved to the newly created eSDK tree under esdk.xx.yy.zz/tools. Make sure that the e-gnu symlink at the same place is linked to the new gnutools directory.
Postby CIB » Thu Aug 01, 2013 11:49 pm
Okay, that took me some time to decipher. In addition, it seems I also have to set EPIPHANY_HOME to that esdk.x.x directory. After that, calling sdk/build-sdk.sh seems to have worked.
CIB
Postby CIB » Fri Aug 02, 2013 3:16 pm
Got it compiled now using all the instructions I got here, but there still seems to be something missing: https://github.com/adapteva/epiphany-sdk/issues/3
CIB
Postby CIB » Sat Aug 03, 2013 2:21 pm
Figured out the issue(had to install MPC etc into gcc/ before running build-toolchain.sh). Updated the wiki accordingly.
CIB
