Epiphany/ARM toolchains?
Postby CIB » Sun Aug 04, 2013 2:33 pm
The parallella incorporates two separate architectures, one for the epiphany itself, and one for the ARM CPU. Are compilers for both included in the eSDK? If not, how do we access e-lib from the ARM core?
CIB
Re: Epiphany/ARM toolchains?
Postby Gravis » Sun Aug 04, 2013 4:27 pm
Postby ysapir » Sun Aug 04, 2013 4:49 pm
Postby CIB » Sun Aug 04, 2013 5:32 pm
CIB
Postby ysapir » Sun Aug 04, 2013 5:47 pm
Generally speaking, we intend for the host target compiler to be whatever toolchain you prefer, as long as it can link with libe-hal.so, and is more-or-less consistent with the naming convention of the GNU toolchain.
If you see that your host code compiles as an x86 code, it probably means that you use gcc as your build command on the x86, while the correct name for the ARM cross tools should be a-gcc (and a-*** in general).
