loading literal constants, and floats.
Postby notzed » Tue Aug 27, 2013 9:03 am
Is there any way to load a float constant in the assembler as a literal? (without resorting to converting it to hex externally)
It doesn't seem to even recognise float numbers at that point.
I also noticed that anything greater than 16-bits is silently truncated in a mov.
Re: loading literal constants, and floats.
Postby ysapir » Tue Aug 27, 2013 1:46 pm
Postby ysapir » Tue Aug 27, 2013 1:49 pm
Immediate moves can assign only 16-bit numbers to either the low half of the reg (zero extended) with `mov r1,#val` or to the high half of the reg using `movt r1,#val`. The macros HI() and LO() should help you select the required part of the immediate value.
Postby notzed » Fri Aug 30, 2013 4:15 am
Postby ysapir » Fri Aug 30, 2013 1:38 pm
Postby timpart » Fri Aug 30, 2013 4:40 pm
Postby notzed » Thu Oct 24, 2013 7:34 am
Postby amylaar » Thu Apr 03, 2014 8:17 pm
amylaar
Postby notzed » Sun Apr 06, 2014 2:12 am
Return to Assembly
