I2C Regulator reprogramming
Postby tnt » Tue Aug 27, 2013 10:16 am
I was wondering where the reprogramming of the I2C regulator was happening ?
For the rev1 the default voltages are a bit on the high side
- 1.2v for the epiphany while it should be 0.9v - 1.1v
- 1.5v for the DDR3 while nominal value is 1.35v
But since you need to shutdown the regulator output to reconfigure, if you want to change the DDR voltage, that needs to be done _very_ early, before RAM is even initialized ... (so like fsbl ? or is u-boot initializing the ram controller)
Sylvain
Re: I2C Regulator reprogramming
Postby aolofsson » Tue Aug 27, 2013 12:17 pm
I2C reprogramming is currently done in uboot.
Postby tnt » Tue Aug 27, 2013 1:08 pm
I guess it's not yet in any published code ? Because I don't see it.
Postby aolofsson » Tue Aug 27, 2013 3:21 pm
Postby tnt » Wed Aug 28, 2013 6:42 am
Mmm, that's probably too late to change the DDR voltage. It would need to be done in low_level_init before it switches to C I think. (I think when it switches to C it expects RAM to be up).
Postby aolofsson » Wed Sep 04, 2013 11:47 pm
Boards finished assembly today (slight delay..). We'll let you know how things go at power up. Agree that a safer avenue would be to change the DDR voltage without reading from DRAM, but a gradual drop from 1.5V to 1.35v should work..
