single bit test in one instruction
Postby notzed » Fri Aug 30, 2013 3:58 am
Re: single bit test in one instruction
Postby Gravis » Fri Aug 30, 2013 9:35 pm
Postby EggBaconAndSpam » Fri Aug 30, 2013 9:48 pm
do not forget pipelining, IALU operations do not cause stalls (in this scenario)...
-test, bit is constant
lsl // 1 cycle
blt // 1 if not taken, 4 if taken
b // 4, use plain branch instead!
overall we are talking about either 5 or 6 cycles, inlining would make sense
-bit stored in register
mov // 1
sub // 1
lsl // 1
blt // 1 or 4
b // 4
overall either 7 or 8 cycles
// write this in C instead, the compiler might be able to do (31-param) at compile time!
// also, inlining!
EggBaconAndSpam
Postby timpart » Sat Aug 31, 2013 1:47 pm
For other playing around with bits tips, take a look at . It is in C code but using operators that easily translate to assembler in most cases.
I ignore the first 3 cycles of an instruction when thinking about timings. They get hidden in the pipeline overlap.
Postby EggBaconAndSpam » Sat Aug 31, 2013 2:00 pm
those 3 particular pipeline stages are responsible for the 3 cycle branch penalty
EggBaconAndSpam
Postby Gravis » Sat Aug 31, 2013 6:16 pm
Postby notzed » Mon Sep 02, 2013 3:10 am
Postby hewsmike » Mon Sep 02, 2013 6:33 am
hewsmike
Postby Gravis » Tue Sep 03, 2013 6:25 pm
Postby notzed » Wed Sep 04, 2013 2:59 am
Return to Assembly
