64 bit off-core writes in C
Postby notzed » Wed Oct 09, 2013 2:45 am
Re: 64 bit off-core writes in C
Postby jeremybennett » Wed Oct 09, 2013 8:59 am
What does -Os or -O2 do? Alternatively put this in a separate file and compile it with -O3 and the rest with -Os.
You can also control the invididual optimizations with the various -f flags. I'll pass this on to Joern Rennecke (who ported GCC) to see if he has any suggestions.
Jeremy
jeremybennett
Postby ysapir » Wed Oct 09, 2013 12:13 pm
This problem is known and AFAIR, the only bulletproof solution is to use extended inline assembly for forcing the STRD instruction.
Postby amylaar » Wed Oct 09, 2013 12:24 pm
amylaar
Postby amylaar » Wed Oct 09, 2013 12:35 pm
P.S.: It would be interesting to hear what experiences people have with -fno-split-wide-types in general.
If the subreg pass does generally more harm than good for epiphany, we can change the default.
amylaar
Postby over9000 » Thu Oct 10, 2013 12:27 am
Would adding __attribute__((aligned(64)) on the pointer (edit: and struct) cause it to use the correct instruction?
over9000
Postby notzed » Thu Oct 10, 2013 2:44 am
Postby over9000 » Thu Oct 10, 2013 3:53 am
over9000
Postby ysapir » Thu Oct 10, 2013 8:37 am
FYI, in the past, I tried using __builtin_assume_aligned() intrinsic for function arguments, but the results weren't consistent either.
Postby amylaar » Thu Oct 10, 2013 9:35 am
Epiphany aligns the stack pointer to multiples of 8 bytes. And the biggest alignment for types (in the absence of attributes) is also 64 bit, so that's what long long gets.
amylaar
