How to install mpfr, gmp, mpc
Postby jimmystone » Sat Oct 12, 2013 5:32 pm
jimmystone
Re: How to install mpfr, gmp, mpc
Postby ysapir » Sun Oct 13, 2013 12:04 am
Did you read the INSTALL instructions I linked on your other question? It tells you how to install the prerequisites. To make sure the three libraries are getting installed, run the apt-get on each one separately and see that it goes through the installation process.
Postby jimmystone » Sun Oct 13, 2013 5:38 am
jimmystone
Postby jeremybennett » Mon Oct 14, 2013 7:54 am
Hi jimmystone,
Another option is to download the source for these components and unpack in the main gcc directory. They should then build automatically from source as part of the the GCC build sequence.
I've not tried this with Epiphany, but it works for other architectures.
HTH,
Jeremy
jeremybennett
