How can I know about my code size
Postby jimmystone » Wed Oct 16, 2013 10:54 am
Hi, All
Since there is only 32KB memory for each core for both data and code.
How can I know the size of my code if I get the elf file and srec file.
Thanks.
jimmystone
Re: How can I know about my code size
Postby simoncook » Wed Oct 16, 2013 11:11 am
Useful SDK Links: - - -
simoncook
Postby ysapir » Wed Oct 16, 2013 12:02 pm
If you have the SREC file, then another, very rough method, for a loadable size estimate is to divide its size by 2. The SREC is an ASCII representation of the loadable objects, so each byte is represented by a pair of characters. As before, you may want to separate the external records from the internal records, based on the address field.
