section names inconsistencies
Postby notzed » Sun Nov 03, 2013 11:57 pm
This isn't a big issue but it would be nice if the section names from the sdk were a bit more consistent and fitted with existing toolchain conventions.
Specifically ...
IVT_RESET, ivt_entry_software_exception, etc ...; they don't specify .text sections, and the names are inconsistent (and even renamed in the linker script)
workgroup_cfg, ext_mem_cfg; they don't specify .data sections, and are renamed in the normal linker script?
text_bankN, data_bankN; they should be .text.bankN, .data.bankN (and add .bss.bankN) to indicate their type.
code_dram; what is it? code? data? How is it different to shared_dram? Overall a bit confusing, no types are specified and doesn't handle bss either.
Having the wrong section types (i.e. .text, .data, .bss prefixes) means objdump isn't as useful as it could be for example.
