gcc/llvm Cilk support
Postby versionzero » Tue Nov 19, 2013 6:57 am
If anyone is interested, and for the sake of reducing duplicate work, I mention that I have begun work on a patch to enable the Cilk language extensions on the Epiphany processor. Nothing noteworthy at present, though I do have the original MIT version working on multi-core ARM. Once I have access to a test board, I plan on getting it working on the Epiphany chip.
Best,
-B
versionzero
Re: gcc/llvm Cilk support
Postby philtor » Tue Nov 19, 2013 4:56 pm
Cool. Do you need any help? Could you host on github so we can at least follow progress? I've been really interested in learning LLVM to this level so I could add cilk extensions.
philtor
Postby versionzero » Tue Nov 19, 2013 9:52 pm
versionzero
Postby versionzero » Sat Nov 23, 2013 8:17 am
Ok, I can't promise the result is pretty, but here is a tweaked (for ARMv6+) version of the original MIT Cilk compiler:
https://github.com/versionzero/cilk
This is just a starting point, as far as I'm concerned. I think using this compiler for now might be the best approach, since it doesn't require an in-depth knowledge of the gcc or LLVM stack-- and it just works. (There's a lot of thing missing that are in Cilk++, but for experimental purposes, this compiler will suffice.) Either way, the next step is to add the ability to run code on the Epiphany cores.
Once the code is in place, I will run a series of experiment to determine how best to schedule across the Epiphany cores. Only then will I move on to the LLVM code.
By the way, if you just want to see the Cilk extensions at work in gcc or LLVM, you can download the source here:
https://www.cilkplus.org/download
and more interestingly, here:
http://cilkplus.github.io
Best,
-B
versionzero
Users browsing this forum: No registered users and 36 guests
