TRAP codes not very well explained
Postby alexrp » Tue Dec 10, 2013 2:08 pm
The codes that are valid for TRAP are not very well documented in the architecture manual.
* It's not clear what 3 does. How is the exit code actually passed along?
* What is 4 even used for?
* Can the reserved codes be used by applications or does reserved mean "reserved by the ISA" here?
alexrp
Re: TRAP codes not very well explained
Postby alexrp » Tue Dec 10, 2013 2:11 pm
The system call table is also incomplete with regards to the actual system calls made in the Newlib port.
alexrp
Postby alexrp » Tue Dec 10, 2013 2:22 pm
And finally, the text should explain that when the core resumes after the TRAP, R3 will hold the error code (non-zero if error) and R0 will hold the result.
alexrp
Postby mhonman » Tue Dec 10, 2013 7:05 pm
A while back I put some trap notes in the documentation errors thread, here: .
Also see the post that follows it.
As far as I can tell trap 4 is not reserved for any architectural reason - it looks like it may have been used in an earlier version of the SDK - traps 0 - 2 are write, read and open functions that seem to have been superseded by the Trap 7 syscalls.
If you are thinking of adding trap functionality, it may be best to do so by extending the range of functions that map to the syscall trap.
Hope this helps!
mhonman
