No epiphany-sourceware repo on the Adapteva org
Postby alexrp » Wed Dec 11, 2013 2:42 pm
It took me a good bit of searching around to find the sources for the simulator here: https://github.com/embecosm/epiphany-sourceware
This should probably be moved/forked to Adapteva's org on GitHub?
alexrp
Re: No epiphany-sourceware repo on the Adapteva org
Postby 9600 » Wed Dec 11, 2013 3:59 pm
Postby simoncook » Wed Dec 11, 2013 4:45 pm
Hi alexrp,
The simulator exists in https://github.com/adapteva/epiphany-gdb. Due to changes upstream it is now not possible to have an epiphany-sourceware repository (as binutils and gdb have moved from the sourceware repo which was previously tracked to their own).
What previously was epiphany-sourceware is now epiphany-gdb, epiphany-binutils, epiphany-newlib, epiphany-cgen, all under adapteva on GitHub. This is documented in viewtopic.php?f=13&t=471.
Hope this helps,
Simon
Useful SDK Links: - - -
simoncook
