Is clk timing active in idle mode?
Postby alexrp » Thu Dec 12, 2013 1:46 pm
So there's the idle timing mode that only counts down while the processor is in idle mode. But I'm curious if the clk mode always counts down, even while the processor is in idle mode, or if it only has effect while the processor is fetching instructions?
alexrp
Re: Is clk timing active in idle mode?
Postby aolofsson » Fri Dec 13, 2013 5:41 am
When counting clock cycles, the timer counts every rising edge of the clock irrespective of the CPU operating mode.
Postby alexrp » Fri Dec 13, 2013 7:49 am
Thanks Andreas!
alexrp
