is x86_64 cross compile sdk working
Postby ed2k » Sun Dec 22, 2013 7:24 am
http://www.adapteva.com/announcements/t ... 5-release/
ftp://ftp.parallella.org/esdk/esdk.5.13 ... armv7l.tgz
I downloaded the version 5 sdk to test on zedboard E16. seems the none of the sdk/example makefile pointing to a-gcc for cross compiling host program.
Is it tested working?
ed2k
Re: is x86_64 cross compile sdk working
Postby alexrp » Mon Dec 23, 2013 11:51 am
I've built programs with this version of the toolchain and used them while developing my simulator, for what it's worth. I haven't had any issues.
alexrp
Postby jeremybennett » Mon Dec 23, 2013 2:24 pm
Hi ed2k
As far as I'm aware this all still works. Could you post a log of your problem.
Best wishes,
Jeremy
jeremybennett
Postby ed2k » Wed Dec 25, 2013 6:18 pm
I am questioning the build script, such as epiphany-libs/build-libs.sh, or build.sh under examples.
Depends on how do you want to run the host program,
By default the host program makefile should call a-gcc to have cross compilation, i.e build at x86 system run at parallella board.
Only when we want to run host program at simulated environment, the makefile calls x86 gcc.
ed2k
Postby ed2k » Thu Dec 26, 2013 11:47 pm
also I just tried the cross compiler from esdk.5.13.07.10_linux_x86_64_armv7l.tgz
it is not working. not passing hello world test on zedboard.
the one works for me is from ubuntu distro arm-linux-gnueabihf-
ed2k
Postby alexrp » Thu Dec 26, 2013 11:54 pm
How did you compile your program?
alexrp
Postby ed2k » Fri Dec 27, 2013 12:13 am
ed2k
Postby alexrp » Fri Dec 27, 2013 4:30 am
alexrp
Postby ed2k » Fri Dec 27, 2013 5:43 am
ed2k
