Does e-run not respect the ACTIVE bit?
Postby alexrp » Sat Dec 28, 2013 3:22 am
alexrp
Re: Does e-run not respect the ACTIVE bit?
Postby timpart » Sat Dec 28, 2013 1:38 pm
The ACTIVE bit is bit zero of STATUS. Bits 0 to 2 of this register are read only. Use FSTATUS instead and see if you get what you expect.
Postby alexrp » Sat Dec 28, 2013 4:05 pm
Thanks for the clarification!
Unfortunately, writing to HSTATUS (this is the name e-as apparently uses for FSTATUS) does not seem to make a difference.
alexrp
Postby aolofsson » Thu Jan 02, 2014 3:28 am
The purpose of having the HSTATUS register allowing us to write to all bits in the STATUS register was mostly for debug, so there may be a mismatch between the simulator and the hardware. It hasn't been tested but writing a 0 to the FSTATUS[0] "should" flush the pipe and stop fetching.
The tested way of halting the processor would be to write to the DEBUG register.
