Various unclear floating point semantics
Postby alexrp » Wed Jan 01, 2014 4:01 pm
While implementing simulation for the various floating point instructions, I came across several things that are not entirely clear.
1. For FMADD/FMSUB, should a NaN result have the sign bit of RD ^ RN ^ RM, or just RN ^ RM?
2. Do FMADD/FMSUB not actually check for RD == NAN in Operation?
3. When an FPU exception is raised, should instructions still yield useful/well-defined results?
4. Some Operation descriptions for floating point instructions set some kind of N flag. What is this?
alexrp
Re: Various unclear floating point semantics
Postby timpart » Wed Jan 01, 2014 10:59 pm
Postby aolofsson » Sun Jan 05, 2014 9:38 pm
Thanks Tim! It will be fixed!
Postby aolofsson » Sun Jan 05, 2014 11:59 pm
Missed the first three questions...
Q: For FMADD/FMSUB, should a NaN result have the sign bit of RD ^ RN ^ RM, or just RN ^ RM?
A: It follows this exact logic:
nan_result_flag= rn_is_nan ? rn[31] :
rm_is_nan ? rm[31] : rd[31];
Q: Do FMADD/FMSUB not actually check for RD == NAN in Operation?
A: Yes they do.
Q: When an FPU exception is raised, should instructions still yield useful/well-defined results?
A: quiet NAN is returned
Postby alexrp » Mon Jan 06, 2014 6:24 am
Regarding the first question:
1. Is this the same logic used for other floating point operations than FMADD/FMSUB? Or is that logic more like `nan_result_flag = rn_is_nan ? rn[31] : rm[31]`?
2. This logic isn't actually exactly equivalent to XORing the sign bits, is it?
alexrp
Postby alexrp » Sat Jan 11, 2014 6:13 pm
@aolofsson ping - did you see my two extra questions?
alexrp
Postby aolofsson » Wed Jan 15, 2014 4:04 am
Postby alexrp » Wed Jan 15, 2014 5:07 am
Should I implement the XOR behavior or the chained-?: behavior? Which is more likely to be future-proof?
alexrp
Postby alexrp » Tue Feb 04, 2014 1:52 pm
@aolofsson - ping in case you didn't see this :)
alexrp
Postby aolofsson » Wed Feb 05, 2014 2:08 pm
I recommend implementing the chained logic that I provided, since this covers the current two versions of the chip (Epiphany-III and Epiphany-IV).
I suspect there will be more than one interesting corner case popping up once we start running validation software comparing the simulator to the cgen model. :D
