Does parallella support wcg project?
Postby busywarrior2 » Fri Jan 03, 2014 1:48 pm
is it possible to run the wcg projects on this board?
busywarrior2
Re: Does parallella support wcg project?
Postby 9600 » Fri Jan 03, 2014 2:07 pm
If there is an ARM/Linux port of the application in question the answer is probably, yes. However, by default applications will just make use of the ARM cores, and development work or "porting" is required in order for apps to be able to access the Epiphany accelerator. This applies to WCG applications, other BOINC-based applications and software in general.
Postby Bikeman » Fri Jan 03, 2014 8:05 pm
Bikeman
Postby Glen » Mon Nov 17, 2014 8:09 pm
New BOINC version 7.4 supports Parallella
Glen
Postby 9600 » Tue Nov 18, 2014 9:58 am
