Overcomplicated formula in LDR/STR with immediates
Postby alexrp » Wed Jan 08, 2014 6:22 pm
alexrp
Re: Overcomplicated formula in LDR/STR with immediates
Postby timpart » Wed Jan 08, 2014 11:20 pm
Postby alexrp » Wed Jan 08, 2014 11:27 pm
alexrp
Postby ysapir » Thu Jan 09, 2014 10:59 am
But, this means that you now have to explain to the reader what size is, and refer him/her to the decode table?? Thanks, I'd rather stick to the current description...
Plus, you are tying two similar-but-not-identical quantities, as the opcode version should really be read as "size code" rather than "size". Furthermore - what if the "code" changes in future revision?
Postby timpart » Thu Jan 09, 2014 12:11 pm
I agree that the existing formula should be retained. One possibility is to add a little quick reference table giving the result for various data sizes.
Postby alexrp » Thu Jan 09, 2014 7:37 pm
alexrp
Postby ysapir » Thu Jan 09, 2014 9:04 pm
Postby alexrp » Thu Jan 09, 2014 10:39 pm
alexrp
Postby aolofsson » Fri Jan 10, 2014 8:56 pm
To answer the tangent question.
1.) We would of course like the Epiphany to be a general purpose architecture but that is not likely to happen any time soon...
Right now the Epiphany serves as a coprocessor to ARM/MPIS/x86. It's definitely not limited to embedded applications, now or in the future!
2.) It would take something absolutely monumental for us to decide to break binary compatibility. Basically, we will only change things if the feature is completely broken or practically unusable. The only exception is chip level register like IO. For example, note that the Epiphany-III and Epiphany-IV are binary compatible.(minus the excause register which is broken on Epiphany-III anyway)
