Parallella Tips and Tricks
Postby dsouth » Fri Jan 10, 2014 2:45 pm
What have you encountered along the way? This is a place to share the lessons you have learned: helpful hints, links to other discussions that have found a resolution, and solutions to challenges.
dsouth
Re: Parallella Tips and Tricks
Postby dsouth » Fri Jan 10, 2014 3:28 pm
Serial Cable Connection
This is the serial cable that I have used with the Parallella:
http://www.adafruit.com/products/954#Technical_Details
Connect the white (RX) wire to the Parallella's TX pin
Connect the green (TX) wire to the Parallella's RX pin
Connect the black (GND) wire to the Parallella's GND pin
Do not connect the red power wire to the Parallella.
Connection to the Parallella is 115,200 bits per second, eight data bits, no parity, one stop bit (8N1)
dsouth
Postby dsouth » Fri Jan 10, 2014 3:38 pm
Parallella Verified Accessories
Thanks to everyone who has updated this wiki!
dsouth
Postby dsouth » Fri Jan 10, 2014 3:46 pm
How to make Ubuntu Run Faster
Here are some great suggestions by shodruk:
dsouth
Postby magorian » Fri Jan 17, 2014 9:34 pm
I have had a great deal of trouble with uUSB and uHDMI adapters:
uUSB:
http://www.amazon.com/dp/B00BFYH11Q
The default adapter version that comes up is too wide and BREAKS THE CONNECTOR with the uHDMI there too, since the connectors are so close. They went back to Amazon and were replaced by the 5 inch size version.
uHDMI adapter:
These blank the screen but no text, tried on multiple monitors that have only dvi and vga no hdmi, so you have to use an adapter from dvi. Adapteva is investigating a working combo.
6-ft version: http://www.amazon.com/gp/product/B00B9H6VT2
http://www.amazon.com/StarTech-com-HDMI ... B000GE9XRQ
Dan
magorian
