NFS on Parallella
NFS on Parallella
Postby uusliu » Mon Jan 20, 2014 6:00 pm
Need some help with getting NFS to work on the Parallella.
Did a
# sudo apt-get install nfs-common
then tried a
# mount 10.101.11.67:/volume1/share /mnt/nfs1
mount.nfs: No such device
Did a
# lsmod | grep nfs
found that it did not return anything so I do not have the nfs module
Did a
# modprobe nfs
FATAL: Module nfs not found.
Saw that the nfs module is available
root@parallella-b0:/usr/src/linux-headers-3.7.0-1-linaro-origen/fs# ls
9p cachefiles exofs hfsplus logfs omfs sysfs
Kconfig ceph exportfs hostfs minix openpromfs sysv
Kconfig.binfmt cifs ext2 hpfs ncpfs proc ubifs
Makefile coda ext3 hppfs nfs pstore udf
adfs configfs ext4 hugetlbfs nfs_common qnx4 ufs
affs cramfs fat isofs nfsd qnx6 xfs
afs debugfs freevxfs jbd nilfs2 quota yaffs2
autofs4 devpts fscache jbd2 nls ramfs
befs dlm fuse jffs2 notify reiserfs
bfs ecryptfs gfs2 jfs ntfs romfs
btrfs efs hfs lockd ocfs2 squashfs
Anything else I can check?
Thanks!
uusliu
Re: NFS on Parallella
Postby over9000 » Mon Jan 20, 2014 11:44 pm
over9000
Postby magorian » Tue Jan 21, 2014 6:00 pm
parallella-6e:~> sudo apt-get install nfs-common
parallella-6e:~> cat /proc/filesystems | grep nfs
parallella-6e:~>
Nope, installs but doesn't work. Like everything in the 12/24 12.04 PoC image: "more difficult than it should be". Versus comes right up after the install on an Ubuntu 13.10 x86 SoC:
itc-eng@nettest02:~$ cat /proc/filesystems | grep nfs
nodev nfs
nodev nfs4
nodev nfsd76
My guess is an x86 dependency. The question is, how to fix it.
Dan
magorian
Postby over9000 » Tue Jan 21, 2014 10:57 pm
over9000
Postby uusliu » Thu Jan 23, 2014 7:34 pm
Thanks for the NFS tips. I will give it a try. Glad to hear that NFS works on the Pi!
uusliu
Postby coffeespoons » Mon Jun 02, 2014 7:38 pm
coffeespoons
Postby joseluisquiroga » Thu Dec 15, 2016 10:35 pm
As an alternative to NFS (which I could not install in the 2016.11 image) I am using sshfs:
Login to the parallella board and just:
sudo apt-get install sshfs
mkdir sshfs-test
sshfs your-destop-user@your-desktop-addr:/a/dir/in/your/desktop ./sshfs-test/
joseluisquiroga
