Where is an SD Card image that works?
Postby dmackenziephoto » Mon Mar 03, 2014 9:17 pm
Flashed the Parallella16_z7020wGPIO_131220.zip IMG onto my SD card. Plugged it in. Turned on the power then nothing. Can't see an IP address to connect too, and all I get on the monitor is a message saying Not Optimum Mode.
Can someone point me at an SD Card image that works? Currently all I have is an expensive ornament.
dmackenziephoto
Re: Where is an SD Card image that works?
Postby shodruk » Tue Mar 04, 2014 8:10 am
This thread may help you:
viewtopic.php?f=48&t=844
Postby dmackenziephoto » Tue Mar 04, 2014 10:16 am
Thanks - I'll have a look.
David
dmackenziephoto
Postby aolofsson » Fri Mar 07, 2014 10:34 pm
Apologies for all the confusion with the SD card image!!!
Please follow the SD card creation recipe below:
http://www.parallella.org/create-sdcard
Postby shodruk » Sat Mar 08, 2014 6:06 am
Postby mjremote » Tue May 06, 2014 10:13 pm
The issue for me is getting the SD card partitioned first. the "flexible" instructions (http://www.parallella.org/create-sdcard/) say to create a
128MB FAT32 + Remainder (>6GB) EXT4.
I have not found a windoze program to do that yet
MiniTool Partition Wizard does not all anything larger than 64KB for a FAT32.
SDFormat, SDMinste, don't recognize the type of SD card.
Yes I plan to setup a dual boot on the laptop for Ubuntu but was hoping to validate the 2 parallella boards first.
Anyone been able to partition with windoze per the "flexible" instructions?
MJ
mjremote
