custom board
custom board
Postby emilio » Tue Oct 06, 2015 2:30 pm
Hi
Is it possible to create a custome board with more interfaces, memory etc. Does the licence enables this, is a BoM available.
emilio
Re: custom board
Postby sebraa » Tue Oct 06, 2015 8:18 pm
emilio wrote:Is it possible to create a custome board with more interfaces, memory etc.
Why not?
emilio wrote:Does the licence enables this, is a BoM available.
If you design and build your own custom board, the BoM will consist of the parts you chose. The Parallella itself is open, if I remember correctly. The FPGA eLink interface is.
Re: custom board
Postby emilio » Wed Oct 07, 2015 7:23 am
From what i see the licence is GPL, could i use it comercialy. Would my board also need to be GPL
Is there some links with BOM for the curent board with PCB design schematics
emilio
Re: custom board
Postby emilio » Wed Oct 07, 2015 7:36 am
https://github.com/parallella/parallella-hw?files=1
Found it.
Now my only doubt is about GPL, needs more investigation.
If anyone has info if i can use these designs to create a commercial product without the need to post the source since i need to add proprietary components and IP.
emilio
Re: custom board
Postby tnt » Fri Oct 23, 2015 1:03 pm
Any derivative work of a GPL work needs to be GPL as well. So yeah, your board would need to be GPL too.
