Parallella Community • View topic - Show your Parallella!!
Re: Show your Parallella!!
Postby shodruk » Thu Dec 26, 2013 11:59 am
Postby Sundance » Mon Jan 06, 2014 3:41 pm
OK... - it's late; VERY late, but I was confident that Adapteva would deliver.
The concept of Parallella Computing has been given a boost by the Epiphany chip and I shall be looking forward to see REAL application being developed in Year 2014 - and integration into REAL products in Year 2015 and onwards.
Sundance will - slowly - continue on the path of a developing a 1U Rack with 4095x of these small DSP beast :P - and I guess it will be Year 2016 before we will finish.
Happy Epiphany Year - and well done to the Adapteva Team
Flemming
P.S. The T-Shirt is also lovely ;)
Got it!
Flemming Christensen
Mobile: +44 7 850 911 417;
Skype: Flemming_Sundance
Company Home Page:
Sundance
Postby shodruk » Mon Jan 06, 2014 5:58 pm
4095 core in 1U rack? Terrific!!! :o
but why 409?
Postby Sundance » Mon Jan 06, 2014 6:14 pm
Company Home Page:
Sundance
Postby theover » Mon Jan 06, 2014 7:02 pm
Congrats on the early board, Sundance.
Did you have a chance to test your connector breakout boards, by any chance ?
T.
Postby shodruk » Tue Jan 07, 2014 12:09 am
Postby hewsmike » Thu Jan 16, 2014 10:26 am
Case Mods ?? Start with the logo :
and when placed in the case :
How so ?
- Well a clevererer person than I would have thought of all this before he took the production mask off that came with the case pieces ! :-) :lol:
- In any event, get some 'poster paint' which for me means water based 'durable' paint ( as opposed to 'permanent marker' ). It came as felt tipped pen for me ...
- run the ink all over a given feature especially filling the etched grooves.
- wait until it is well dry.
- gently rub ( not scratch ) off the ink that is flush with the surface. For preference use ever so slightly damp cotton buds ( wet briefly on your tongue ).
- this leaves the color only in the grooves !!
For my effects as above it is metallic flecked gold for 'parallella', pink for the left 'binary' hemisphere, metallic flecked silver for the right 'tracked' hemisphere and black to the enclosing brain outline. For my next trick : the end panel port labels .... :-)
Cheers, Mike.
( edit ) To be perfectly honest my amateur photography does not do justice here .... it really comes up nice and is cheap to do ! :-)
( edit ) I chose water based ink/paint because that's easy to clean off with warm soapy water and a gentle washing action. In case you don't like the result or have stuffed up.
hewsmike
Postby shodruk » Fri Jan 17, 2014 12:38 pm
Good job! :D :o
And thank you for sharing the tips.
Don't you use a cooling fan?
I think it would be good to attach a small fan to the east side window.
And, how about LED lighting?
I think the acrylic case decorated with blue LEDs would be cool.
Postby hewsmike » Sat Jan 18, 2014 6:07 am
OK, now for the fan :
- a heat sink on both the ARM and the Epiphany.
- that's a 40mm 5V DC 0.9W 1990's style Pabst ( #405 ) wired straight into a USB cable ( solder, shrink wrap and a couple of sticky cable stays ).
- use a sparing amount of superglue on the corners to bond to the acrylic.
- the hard part was making a round hole ( obviously disassemble the case first .... ). I used a drill press and a 38mm hole saw : clamp well, pad/protect the workpiece, keep the speed well up and gently/slowly wind the toolbit down.
- currently under 5 degrees C above ambient when idle, going to between 5 - 10 degrees C above when active. Have not yet given it a long thrash though.
All in all, a happy camper. :-)
Cheers, Mike.
hewsmike
Postby Claggy » Sat Jan 18, 2014 9:29 am
Mike has posted further pictures in his thread at einsteinathome.
Claggy
Claggy
