Parallella Community • View topic - USB not working
USB not working
Re: USB not working
Postby e-rod » Fri Jul 11, 2014 4:16 pm
Unfortunately, my results are not 100% reproducible. That is, the workaround does not always seem to work.
My OTG adapter is about 6" in length from end to end. It's this guy here: My standard Micro USB cable is probably a good meter (3 feet) or so, it's the one that came with the Nexus 5.
This morning I tried to boot with the OTG adapter in, no dice. I powered the Parallella off, tried the workaround and it did not work. Interestingly enough, I unplugged both USB and HDMI, power-cycled and it worked. I then plugged HDMI and the OTG adapter back in, they both worked (though I had to soft reboot for HDMI to show properly). It seemed to work now.
I am not sure really, though it is quite mind boggling. It seems like a timing issue in the kernel/boot sequence or something like that.
e-rod
Re: USB not working
Postby Sean S » Tue Jul 15, 2014 1:20 pm
Please vote on the operational state of USB on your board:
viewtopic.php?f=50&t=1483
Hopefully it will help expose the extent of the problem. Thank you!
Sean S
Re: USB not working
Postby IDP » Wed Aug 13, 2014 2:43 pm
Why did someone not fix this for the new release of boards?
Have just received 2 boards which am running Yocto on.
Both boards have problem to initiate the USB 0, but the trick with long cable fixed it temporary.
Any solution to fix it permanent?
IDP
Re: USB not working
Postby Morgaine » Wed Aug 13, 2014 4:03 pm
Morgaine
Re: USB not working
Postby dcd4408 » Wed Aug 05, 2015 7:40 pm
dcd4408
Re: USB not working
Postby ajtravis » Thu Aug 06, 2015 9:02 pm
Re: USB not working
Postby slip » Mon Aug 10, 2015 7:53 am
slip
