Parallella Community • View topic - Slow Epiphany
Slow Epiphany
Re: Slow Epiphany
Postby AndyC » Thu Aug 21, 2014 10:09 am
AndyC
Re: Slow Epiphany
Postby aolofsson » Thu Aug 21, 2014 10:20 am
99% sure that you are fetching instructions from external memory directly without realizing it. Please use e-objdump -D "your.elf" to see where your code is placed.
For example, with the constants you used, pretty sure that they get called in as doubles without a n f specifier. i.e. 1.0f If this is the case, then there will be lots of messy double/float conversion (and this code is read from DRAM!)
Re: Slow Epiphany
Postby AndyC » Thu Aug 21, 2014 10:24 am
Hi Andreas,
Thanks very much for the pointers, I will have a look.
Andy
AndyC
Re: Slow Epiphany
Postby AndyC » Thu Aug 21, 2014 10:30 am
AndyC
Re: Slow Epiphany
Postby AndyC » Thu Aug 21, 2014 10:35 am
AndyC
Re: Slow Epiphany
Postby aolofsson » Thu Aug 21, 2014 10:42 am
Re: Slow Epiphany
Postby sebraa » Thu Aug 21, 2014 1:51 pm
I did the same mistake and solved it by the -fsingle-precision-constants compiler option.
Re: Slow Epiphany
Postby AndyC » Thu Aug 21, 2014 4:54 pm
Another nice tip, thanks!
AndyC
Re: Slow Epiphany
Postby notzed » Fri Aug 22, 2014 12:02 am
Don't put data in text. Text is code. Data is data.
Oh and don't put your automatic variables in a section either. They should just end up in registers or at worst spill to the stack.
Re: Slow Epiphany
Postby AndyC » Fri Aug 22, 2014 5:14 am
Thanks for the pointers.
I thought it wouldn't matter if I put them in the text section due to the way the epiphany works, why would there be a difference between .text and .data on the epiphany?
The variables were just put in a section as I was trying to make sure the linker was not putting them in slow ram when I was trying to work out why it was going slow.
Cheers
Andy
AndyC
