Parallella Community • View topic - robot setup
robot setup
robot setup
Postby andrew28 » Sat Nov 22, 2014 7:30 am
i was wondering what would be the best bord for a robot their are three bords to chose from for the parallella and this robot will be an artoo unit with a lot to it. ill want semi autonomous for the apearince of ai voice comands insted of a remote camra to view route and to know what is or isent in front of him lights voice comand not remote collision detection auto follow preferably a signal along with video and move ment powered by servos so witch parallella or parallellas whould i be needing to operate all this simultaneously the way i will need it to
andrew28
Re: robot setup
Postby 9600 » Sat Nov 22, 2014 2:08 pm
I think you really need to look at the specifications of each and to make your mind up based on whether you need GPIO or just USB, and if you're going to be using the FPGA, whether a Zynq 7010 will suffice or you need a 7020.
Return to Robotics
