Parallella Community • View topic - 4 Parallella Base with Fans & Netswitch
Postby gregb » Sun Mar 22, 2015 5:18 pm
Below are details for building a 4 (or 5) Parallella mounting base with integrated gigabit switch.
I would like to make a shout out to JeremyBennett for giving me a starting point.
I modified his SCAD to integrate a 5 port gigabit switch.
My modified SCAD is available at .
Total cost is around $200 for a clean way to use/display 4 boards.
You could probably shorten the spacers and add a second 5 port switch to mount 5 Parallella.
Here is my equipment list:
Qty 2 - 3D printed base/top ($57ea)
Qty 1 - D-Link GO-SW-5GE 5-Port Unmanaged Gigabit Switch (mounted to base) ($23ea)
(There are two versions of this model, you want the one with LEDs in front, connections in rear)
Qty 4 - 6-inch Cat5e network cables ($8 lot)
Qty 2 - Cooler Master JetFlo 120 - POM Bearing 120mm White LED High Performance Silent Fans ($17 ea)
(removable resistor cables included to adjust fan speed)
1 lot - brass spacers, screws, washers, wires
(Actual cost in range of $20+, but I had to buy packages totaling around $60 to get the few I actually needed. holding on to the rest for future projects.)
Here are some pics of the finished product in ABS grey.
Top-Right View
The dual 120mm fans are a bit of overkill. I had planned to use the inline resistors that come with the fans to reduce their speed. These get pretty hot, so I was going to use the heat for some old style Christmas bubble lights and some brass tubes to steam-punk the final design. Maybe add an old style Ammeter to indicate the gigaflops generated.
Front View
The network switch LEDs were in the way of the posts that hold the Parallella-16 boards, so I extended them with some ribbon cable.
I had planned to mount these LEDs higher (hot melt glue? or modify the 3D base?) where I could see them from a distance.
Rear View
I notched our the base to allow for the CAT5e cables and I cut down some of the plastic around the connectors to fit around the brass posts.
gregb
Re: 4 Parallella Base with Fans & Netswitch
Postby gregb » Sun Mar 22, 2015 5:25 pm
The folks at Shapeways.com gave me a credit to try them out. Since it was free... I had them build a base out of ceramic.
Ignoring the fuzz and dust in the picture... the result was ceramic... with a gloss black finish.... but it is not precision enough for the application.
When it was fired, the fan mounting posts spread right and left. You can see some additional distortions in the second picture.
Top down
Ceramic Base
Underside
Underside of base
Side view - Ceramic base versus plastic base
Side
gregb
Postby gregb » Sun Mar 22, 2015 6:00 pm
I am selling these parts because my other projects are taking all my spare time.
If you are interested, please see this post
gregb
Postby aolofsson » Mon Mar 23, 2015 1:56 am
Awesome project! You make it look easy.
Leverage in action. One project builds on another, that builds on another,... I wish we had more examples like this.
