Parallella Community • View topic - Using OpenCL extensions - memcopy
Moderator: dar
Postby nickoppen » Mon Dec 29, 2014 9:23 am
How does one use OpenCL extensions - specifically memcopy?
A number of examples (e.g. mandelbrot and matmul) use memcopy and there are no clues as to how to include them in compile or link.
There are two candidates as far as I can see: e32_opencl_ext.h and coprthr_device.h but they churn out reems of compile errors for other included files.
Any clues?
nickoppen
Re: Using OpenCL extensions - memcopy
Postby Gideon » Thu May 28, 2015 1:45 am
Have you resolved this problem?if you have done,can you give me a detail, thanks a lot.
Gideon
Postby nickoppen » Thu May 28, 2015 9:26 am
Hi Gideon,
DAR's reply to your other post is the best I've got.
It didn't seem very encouraging. I was going to have a look at MPI anyway so I'll try and figure out what he is driving at.
nick
nickoppen
Postby dar » Thu May 28, 2015 1:31 pm
Did not mean to be discouraging. If you get a chance can you send the full output of compiler errors you see as a text file to dar at browndeertechnology dot com. I am just curious. If its an easy fix, I would like to help. Its just been some time since these extensions were tested.
Link to a paper on threaded MPI can be found here if interested or just curious:
viewtopic.php?f=53&t=2441
-DAR
dar
Postby Gideon » Fri May 29, 2015 12:57 am
Hi Nick
I will also have a try on MPI, thanks anyway!
-Gideon
Gideon
Return to OpenCL
