Parallella Community • View topic - does the board contains thermal sensor(s) ?
Re: does the board contains thermal sensor(s) ?
Postby bszente » Mon Jun 02, 2014 11:13 am
Parallella board with fan
bszente
Postby kloetzl » Fri Apr 03, 2015 7:54 pm
kloetzl
Postby olajep » Tue Apr 28, 2015 2:25 pm
Postby fsalerno74 » Fri Jul 03, 2015 9:09 pm
Hi folks.
thank you all for the precious help, i found the script very useful.
I'm new to the parallella world, just received the board today!
i found really useful the script because i started connecting via Win the board and cant use the graphic interface.
with the heatsink provided i recorded pretty high temp even with idle board - 76°C.
with heatsink only.
zynq temp up no fan.JPG (10.78 KiB) Viewed 21139 times
i found some interesting post using a 5v fan but i'm not confortable with soldering..
so i used an old small case fan - 12v - connected to the pc power.
temperature dropped to 55.7 °C at idle.
with 12v fan
zynq temp up 12v fan.JPG (9.11 KiB) Viewed 21139 times
tomorrow i'll use an old 12v adapter from a notebook to make a dedicated power supply.
i'll also try the improved scripts.
sorry if i posted in the wrong place! noob deserve some patience :P
best regards.
FS.
fsalerno74
