PORCUPINE BOARD
Re: PORCUPINE BOARD
Postby meant2invent » Thu Jul 02, 2015 10:05 pm
Hi Guys, instead of starting out with a more complicated board like above I think I am leaning towards a very simple 60 pin breakout like the one below. I would sell it for around $30. There would be nothing fancy about it, just a Samtec to .1" header converter. Once I create this board I will move on to create further more complicated boards. Any thoughts?
meant2invent
Re: PORCUPINE BOARD
Postby jahorin » Mon Jul 06, 2015 6:11 pm
@meant2invent I like the idea a lot of just doing a simple breakout just to get boards connected. The 0.1" is a good idea since it's more readily available from what I've seen than the 2.5mm. From a consumer standpoint, the cheaper the better for something simpler. If you could suggest the corresponding header and cable that go with the connector you choose upon manufacturing, it'd be much appreciated.
jahorin
Re: PORCUPINE BOARD
Postby meant2invent » Tue Aug 11, 2015 2:05 am
Jahorin, you hit the nail on the head. Simple is the best in most cases. My boards just came in and now they will be entering the assembly phase. Are you interested in one?
meant2invent
