Parallella Community • View topic - What kind of accessories do we need?
Postby awong209 » Mon Apr 29, 2013 7:11 pm
I am excited to see to see the boards shipped very soon hopefully. As we all gear up for the arrival can you guys refresh us as to what we will need to get additionally to get the Parallella boards booted?
- SD Card
- Keyboard/Mouse [preferably wireless combo]
- power cord? [and if so what specs?]
- HDMI cable
Is there anything else I am missing?
awong209
Re: What kind of accessories do we need?
Postby 9600 » Tue Apr 30, 2013 9:14 am
Postby awong209 » Mon Jul 01, 2013 2:47 pm
on the Parallella Board specs the USB drive is labeled as uUSB. Since the HDMI and SD both have that I am assuming that the USB drives will be micro USB drives?
If that is that case I would presume people will need to buy a mico USB adapter in order to plug in their USB keyboard and mouse correct?
awong209
Postby 9600 » Mon Jul 01, 2013 4:21 pm
The USB ports use Micro-USB connectors so, yes, you may need an adapter for use with some peripherals.
Postby Marcus D. » Tue Jul 23, 2013 12:18 pm
For the adapter, do you need just a normal micro-usb adapter, or a USB-OTG one? Or does either work?
Marcus D.
Postby Marcus D. » Tue Jul 23, 2013 2:58 pm
I see it says OTG. But refers to 2 OTG. Anyone know how that works given only one OTG header?
Marcus D.
Postby cklin » Tue Aug 27, 2013 4:31 pm
cklin
Postby gceline » Tue Aug 27, 2013 9:15 pm
1) New image of case is uploaded on the shop - it is stackable and has covers. http://shop.adapteva.com/collections/ki ... lla-case-1
2) PSU is 5V 2A with a 'standard' 5.5mm OD, 2.1mm ID positive tip connector
3) SD card will not be flashed - image will be available online with instructions
Graham
Adapteva
gceline
