Bare metal application with FPGA co-processor
Re: Bare metal application with FPGA co-processor
Postby aolofsson » Fri May 20, 2016 6:48 pm
Great stuff. Thanks for posting this on the forum!
Timing paths:
Based on where those paths are, those paths go to the reset synchronizer. I probably declared those as false paths and forgot to check them in to the constraints back in the fall.
Master:
Master branch needs to be updated to new oh modules for fifos. (either a path issue or a module rename issue)
Yes, your summary sounds good.
Postby eliaskousk » Fri May 20, 2016 7:20 pm
Andreas thank you for the quick reply.
So it seems I have built a good bitstream with vivado 2015.4 and this version can be used for Parallela bitstreams.
Can't wait to try it out on the board!
Best,
Elias
eliaskousk
Users browsing this forum: No registered users and 109 guests
