Set the Stack Pointer Value
Postby SKyd3R » Thu Sep 05, 2019 10:00 am
Hello!
I'm trying to modify the stack pointer value of an eCore but I'm unable to perform that action.
I have tried the C function
e_reg_writer(E_REG_R13)
and also the asm instruction move
r13, 0x7fe8
and also de
move sp, 0x7fe8
. But after the execution the e_reg_read doesn't change at all (I have also tried another addresses just in case).
Is there any way to modify the stack pointer register?
Greetings!
SKyd3R
