Parallella Community • View topic - DIY Source for Samtec Connectors?
Re: DIY Source for Samtec Connectors?
Postby Sundance » Mon Oct 14, 2013 8:56 pm
Sundance can help... - We do this for a living and will only charge for materials and handling in the interest of REAL applications for Epiphany-based solutions. The PCBs will have to on a panel and the most expensive part is the solder-paste stencils.
Contact me by email, please - if you #tnt (or others!) want to take this forward
Rgds
Flemming
Flemming Christensen
Mobile: +44 7 850 911 417;
Skype: Flemming_Sundance
Company Home Page:
Sundance
Postby mark03 » Fri Oct 18, 2013 6:50 pm
tnt, and whomever else is working on daughtercards / breakout boards:
Before I embark on making a footprint for those Samtec BTH connectors in kicad or geda, does one of you already have one?
Mark
mark03
Postby tnt » Fri Oct 18, 2013 9:27 pm
No, not for those packages.
As I mentionned the eagle files are XML so they could possibly be processed automatically by a script. Also SAMTEC itself publishes data of footprint as ascii txt files which you can re-use in scripts.
Sylvain
Postby petr_cvek » Sat Oct 26, 2013 1:02 am
petr_cvek
Postby shodruk » Sat Oct 26, 2013 9:58 am
Is there any protection circuit?
Postby tnt » Sun Oct 27, 2013 1:00 pm
Postby shodruk » Mon Oct 28, 2013 11:45 am
I'm noob in electronics, so I'm worried about breaking my Parallella.
and I was scared after reading this article.
Postby shodruk » Sun Nov 17, 2013 9:50 am
I've learned buffer IC will help me.
Which buffer IC is suitable for Parallella's GPIO?
Postby DarcyThomas » Thu May 08, 2014 3:40 am
I did find these
It uses a samtech connector; and has a similar purpose.
I *think* it would be compatible.
But you would need to double check the gender and pin outs.
DarcyThomas
Postby 9600 » Thu May 08, 2014 7:20 am
