Parallella Community • View topic - Parallella 7010 no GPIO - no Samtec Connectors
Re: Parallella 7010 no GPIO - no Samtec Connectors
Postby FHuettig » Fri Jun 13, 2014 2:50 am
Postby tnt » Fri Jun 13, 2014 6:18 am
Yes, the inertia is definitely still there.
My thinking on this was that you can have custom board connected to those gpios and since the IO voltage is adjustable, it might not be configured correctly yet for that expansion board when the bitstream is loaded and so a pullup would be imposing a potentially too high voltage on the external device. OTOH, 100uA is pretty weak so it's doubtful this would cause any damage ...
Another thing that would be useful for the default GPIO config is that ability to configure state change interrupt on them. Not sure if the default EMIO GPIO module allows this (or maybe it's available already in the current config, I haven't checked).
Postby shodruk » Fri Jun 13, 2014 10:06 am
Is it possible to implement GPIO breakout by soldering lead wires?
Postby tnt » Fri Jun 13, 2014 11:16 am
Sure. There is nothing between the GPIO and the connectors so that board just doesn't the connectors but the signal get to the pad.
Postby shodruk » Fri Jun 13, 2014 12:12 pm
Postby FHuettig » Fri Jun 13, 2014 4:43 pm
Postby 9600 » Sat Jun 14, 2014 2:42 pm
Postby tnt » Sat Jun 14, 2014 2:56 pm
Depends safer for who ... daughter card won't be safer.
And higher voltage means higher power consumption for the HDMI.
Postby 9600 » Sun Jun 15, 2014 9:58 am
Good points.
Postby FHuettig » Mon Jun 16, 2014 3:57 am
Users browsing this forum: No registered users and 130 guests
