Parallella Community • View topic - USB connector
USB connector
USB connector
Postby GraemeP » Sun Feb 10, 2013 11:55 am
Hi
After seeing the latest released pictures of the Parallella board (Project update #28), can I ask is the USB connector a purely surface mount device? We have had issues in the past with our own (and other) boards where a little careless handling can cause a s/m USB connector to be pulled off.
GraemeP
Re: USB connector
Postby moeter » Sun Feb 10, 2013 12:00 pm
Pull off that USB Connector? We always use that type and never had problems in our company! How much force is needed to pull it off?
On an s/m ethernet connector we measured over 3kg to pull that off after a complaint from a customer...
I personally think that is not a real problem. Just be a bit careful ;)
moeter
Re: USB connector
Postby aolofsson » Sun Feb 10, 2013 1:53 pm
Thanks for the heads-up on the problems with some micro USB connectors. We will definitely make sure the Parallella board is robust.
Re: USB connector
Postby trioflex » Thu Feb 14, 2013 5:06 pm
trioflex
Users browsing this forum: No registered users and 139 guests
